Audio signal between detection and activation
BobNordic
Hello,
I have a security system installed using the Smart Home Controller II, Smoke Detector II (for audio), Movement detector and Door detector II.
I have configured a delay of the alarm activation so when the door opens there is time to stop the alarm before activation. However during this time the audio signal is silent and I cannot find any way to configure some audio signal warning that the alarm is turned on and is about to be activated.
Is there any way to configure an audio signal between security detection and alarm activation?
1 ANTWORT 1
No, the smoke detectors cannot be used as audible reminders for the alarm system. But you can enable a visual reminder using a smart lamp (Hue / Ledvance) or a Dimmer. The lamp starts blinking if you don't disable the alarm system within the first half of the configured delay.
You can also build your own reminder using e. g. a smart plug or relais and automations.
