Fire alarm relay compatibility.
FireAlarmGuy
Hi, I’d just like to know whether the Bosch smoke alarm II is compatible with a relay/has one built in and could connect to a fire alarm of the brand ‘Apollo’ Thanks. (Also please send me a link to a solution if you will give me one, thanks) Also, would it be compatible with smart controller? Thanks.
The Smoke Alarm II is compatible with the Smart Home Controller (I and II) - in fact the controller is required for all but the most basic functions. It does not have a built in relay, but a smart relay is available separately. This can be configured as a lamp and the smoke alarm service can switch on all lights connected to the controller in case of an alarm. This should then switch on the smart relay, too (haven't tried that though).
Home Assistant User seit 2026
