am 03. Oktober 2026 12:16
Heizthermostat 2 Funktionsstörung Fehlermeldung Eo5. Das zweite schon diesen Monat. Habe alles versucht, Batterie raus Batterie rein, neu konfiguriert. Letzte Meldungen Motor wahrscheinlich defekt. Was nun!!! Mit freundlichen Grüßen Peter Clever
am 03. Oktober 2026 13:19
Wenn noch Garantie vorhanden ist, solltest du dich beim Support melden.
12. Oktober 2026 10:28 - bearbeitet 12. Oktober 2026 10:29
Hi,
I have the same issue with one of my thermostat (code E05 with a message in SH app) but it's now 3 years old so I think the warranty can't apply. I tried many things but seeing that I won those during a contest I don't have any invoice to open a support ticket. I did everything I could: changing the batteries, calibrating without plugging to the valve, but the motor seems to randomly block.
Kind regards
am 12. Oktober 2026 15:13
Hi @Blacklord049,
thank you for reaching out and sharing your issue with your thermostat.
Please contact our customer service team directly so we can look into this for you. When you submit your request, please make sure to include:
A brief description of the defect/issue you are experiencing.
A copy of your purchase invoice (this is very important to help us verify your case quickly).
Our team is very accommodating, and there is a good chance we can offer a goodwill solution for you.
Smart regards
22. Oktober 2026 00:20 - bearbeitet 22. Oktober 2026 00:26
I just bought a new model. In fact the thermostat I got was won in a contest, 3 years ago, through the Alternate marketplace. Sadly I have no document for that, seeing it's not a purchase... The only thing I can give is the s/n.
In Belgium the warranty is only applicable for 2y and I didn't have any extension (again, it was a prize won during a contest)
After buying a new one I tried resetting the device and even removed the batteries for 2 days. Now when I put the batteries back, the motor is failing with another error code, as if it was stuck.
am 18. Oktober 2026 12:47
i have disassembled the unit like described here:
Then disassemble also until the gearbox.
turn the gear for the stem manually until the stem has moved some milimeters outwards.
Assemble everything again. E05 dissapeared and adoption process works again.
