am 06. April 2025 16:36
There is a problem with the detection sensitivity/mechanism of Matter Double Press, and a high probability that the fast Double Press cannot be recognized. Hope it can be improved in the future firmware.
am 07. April 2025 11:28
Hi @CyberMod-Studio , thank you for your feedback regarding the detection sensitivity of the Matter Double Press function. Please note that the recognition of short press, long press, and double press actions may depend on the capabilities of your Matter controller. We kindly recommend reaching out to the manufacturer of your Matter controller for further assistance, as this behavior may be related to how the controller processes input events.
best regards
am 07. April 2025 20:00
Hi, thank you for your reply. But I don't think this is an effective answer to solve this problem. I have compared and tested other Matter over Thread Generic Switch (wired and wireless). I can continue to list performance comparison videos in the next few days. I think this is the firmware problem of +M Sensor (Leedarson's firmware engineers need to know this problem and optimize it)
am 07. April 2025 22:02
In Home Assistant my Tür-/Fensterkontakt II [+M] is working correct over Thread. Double Press is recognized as fast as is can push the button.
am 08. April 2025 12:01
This is not possible. I have tested Home Assistant and it has the same bug.
am 08. April 2025 12:34
What hardware do you use for your thread network?
am 08. April 2025 16:51
HomePod mini and Home Assistant Green
am 08. April 2025 17:49
I use HAOS on PI4 with ZBT1. Maybe there ist the difference.
am 24. Oktober 2025 08:22
There is no difference, my HomeAssistant Green also runs HAOS+ZBT-1
am 24. Oktober 2025 08:26
Half a year has passed. Is there any new firmware that can fix this problem? In addition, I found another major design flaw of this device: it cannot remove the motherboard, which means that when the button on the body is broken, you will not be able to manually repair and replace it. My button has been malfunctioning/unresponsive after using it for half a year.
am 24. Oktober 2025 13:48
Hello @CyberMod-Studio, please get in touch with our support in case of any malfuntionality with the Bosch Smart Home door/window contact II: Kontaktformular | Contact Form
am 24. Oktober 2025 08:29
The mold design of this device also has issues, with the button section lacking adequate support. This results in an extremely uncomfortable tactile feedback sensation when pressing the buttons from different angles.
