Room Thermostat II - not working valvetappet (no error message), room too cold
misa15
Good afternoon,
Used
- Bosch Home Controller I (10.31.5181-4522),
- Android app 10.31.4176.
Now, for only one Radiator Thermostat II is in Android app showed ventil position (valvetappet) change, but direct on Radiator Thermostat II not hear sound of movement (from 0% to 100%, or back). On other radiators after change temperature up or down is hearable sound of valve movement.
1. Radiator is still cold. Other radiators work like are expected.
2. Direct on Radiator Thermostat II not showed error message.
3. Each Radiator Thermostat II is interconnected with Room Thermostat II. In cold room is the Room Thermostat error or without weak batteries.
4. Batteries on affected Radiator Thermostat II were changed (not showed info about weak battery). Problem is still same.
5. After removing batteries from Radiator Thermostat II, and inserting back was calibrating procedure succesfull (mechanical pin on affected radiator can be moved manually like on other working radiators (all with little bit higher force, no feel difference). Problem is still same (too after reenter batteries).
6. This Radiator Thermostat II was working before (whole last winter (2024) and beginning of this winter (november and december 2025) without problem), only last more days we feel cold in afftected room.
7. All Radiator Thermostats and Room Thermostats had installed last valid firmware version.
8. Created SHC system report 18.1.2026, but no answer from support. And now is in affected bedroom 15,2 oC.
Thank you in advance for smart help.
P.S. During december were one Radiator Thermostat II exchanged (in the different room), but there was showed error E03 or E05 (I am yet not sure).
Ami
could you switch two of your thermostats and test if the one not working is also not working in the other room?
Hi @misa15 , our Service-Team will contact you during this day.
Best regards
