Camera disconnected
FrancoisL
Hello,
Our outdoor camera 2 got disconnected this night.  After shutting down the power, it wasn't solved after a reboot.  A blue light remains static.
Any advice ?
Thanks,
François
Marcel_S
Hallo François,
Can you link this behavior to anything?
Did this happen after a SW update?
Or directly after commissioning the camera?
Please try:
- switch off camera for longer time (> 1 hour)
- power camera again and give the camera some time (> 1 hour)
Rgs / Marcel
FrancoisL
It suddenly stopped working last night no specific event related to it.  Ok I will try to disconnect it for one hour.  Thanks !
FrancoisL
Only a factory reset worked: https://community.bosch-smarthome.com/t5/technische-probleme/smarte-innenkamera-2-leuchtetdauerhaft-...
Is there a way to check the logs to see what happened last night at 4am ?
Hello @FrancoisL,
please send me the support code from the camera app (you can find it under Settings --> Support --> Activate access by support) through personal message.
Then a 16-digit code will appear - with this we can read out the error logs of the camera.
Smart regards
