Automation with e.g. AEG, SIEMENS devices
misa15
Hello,
it is possible to control Aeg or Siemens devices from Bosch Smart Home App.
Or exist any solution?
Thank you.
If the appliances support Home Connect, you can link your Home Connect account to the Bosch Smart Home Controller. This allows you to use them in Bosch Smart Home automations.
It's quite limited though. For my washing machine, I can only use it as a trigger (is started / is finished) or start it. For everything else, you need the Home Connect app. And it's cloud based, so both the appliance and the SHC need Internet access for this to work.
Home Assistant User seit 2026
