Radiator Thermostat II and I - sommer mode
misa15
Good morning,
which position of Radiator thermostat I and II is recommended for summer mode (that means which settings - set temparature to lowest value or set temperature to higher value)?
Thank you.
2 ANTWORTEN 2
If the heating of the flat or house is completely shut off, it does not matter.
Otherwise, set it to the lowest temperature is more meaningful.
In general, the system provides an internal function for that, in the german app version it is called "Heizpause". Unfortunately, I do not not know the exact wording in the englisch version. With that the radiator thermostats are going to the lowest set point and showing "Off" in the display. Just freeze protection and weekly recalibration / descaling of the valve are active. In all other functions like automations and so on, the thermostats will be ignored.
Just set them to heating break in the climate manager:
