Radiator thermostat
- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Direktlink zum Kommentar
- Anstößigen Inhalt melden
vor einer Woche
Hi,
I have a 3 story house and I have radiator thermostat II upstairs. The problem is that the signal is very bad as the Smart Home unit controller is in the basement so the signal for the thermostats upstairs is very bad.
How can I improve the signal from the controller to the thermostats?
br Mee
- Themenübersicht:
Smart Home Controller
- Lesezeichen
- Abonnieren
- Stummschalten
vor einer Woche
Most mains powered Zigbee devices extend the mesh network. You can e. g. place a Plug Compact or a compatible Ledvance lamp somewhere on a floor below the thermostats. Or multiple, if one is not sufficient.
- Lesezeichen
- Abonnieren
- Stummschalten
Freitag
Thank you. Does it work with a Philips Hue bulb?
- Lesezeichen
- Abonnieren
- Stummschalten
Freitag
No, Hue has its own Zigbee network, separate from the Bosch Zigbee network.
- Lesezeichen
- Abonnieren
- Stummschalten
Freitag
Ok. I bought 2 now.
Probably a stupid question, but does the switch need to be on for it to extend the signal?
Eg. If I have a lamp I plug into the plug and I want it to automatically turn off at night. Is the plug still extending the signal to the thermostats, when the lamp is off?
- Lesezeichen
- Abonnieren
- Stummschalten
Freitag
The Plug Compact does not need to be turned on. It extends the network as long as it is plugged in. The Zigbee radio is always active.
