Radiator thermostat II and ??? (like successor for CT200 + radiator termostat I)
misa15
Hello,
Radiator thermostat I can be combined together with CT200 + EasyControl Adapter (only optionaly for non Bosch condens devices).
And CT200 isn´t compatible with radiator thermostat I. Correct?
Exist any possibility (or is planned something):
A. Radiator thermostat II + ??? (for Bosch condens devices)?
B. Radiator thermostat II + ??? + ??? (for non Bosch condens devices)?
Thank you.
@misa15 The CT200 is using communication channel 868 MHz, as the Heizkörper-Thermostat.
Heizkörper-Thermostat II is using ZigBee 3.0 (2,4 MHz) communication and isn’t therefore not compatible with the CT200y
