am 13. Oktober 2022 16:43
Hello,
how can be possible to set in Automation an rule of negation, please?
That means: IF "F1 short" AND "light is on" then "switch off the light " else "switch on the light"?
Thank you.
am 13. Oktober 2022 18:25
You can add two Automation for that.
First.
If press F1 short and Light is off then turn it on.
Second automation.
Press f1 short and Light is on the turn it off.
First.
Second automation.
am 13. Oktober 2022 21:37
Thank you.
How is prevented before make both automation (by your suggestion) in one cycle and then to have first status of device?
am 13. Oktober 2022 21:51
Because of the "and" condition. The light can only be on or off
