Smart Home Controller - put devices to sleep
misa15
Hello,
it is possible (via application)
1. put all devices with one command to sleep/hibernate state?
2. put group of defined devices with one command to sleep/hibernate state? E.g. during summer hibernate the all radiator thermostats, etc.
3. When is possible to make an point 1. or 2. It is possible reverse step - awake?
Thank you.
2 ANTWORTEN 2
@misa15 all cell driven devices are generally in power safe mode, as no action occurs, like i.e. window opening.
All thermostats can be set to heating break in the climate manager. Then the will do only one stroke per week, at Saturday 11am to keep the valve working.
If you're talking about thermostats and the heating break mode: This can indeed be activated and deactivated with scenarios which can include multiple (or all) rooms. The scenarios can be triggered with a single tap in the app.
Other devices don't have a dedicated "sleep / hibernate state".
