Heating (GC2300 iW 22/25) with Bosch Radiator Thermostat I and II
misa15
Hello,
do you have any idea/recommendation how to interconnect condens GC2300 iW 22/25 with Bosch Smat Home Controller I and with more rooms with A.(Room Thermostat I + Radiator Thermostat I) and B.(Room Thermostat II + Radiator Thermostat II)?
When isn´t exist Bosch solution, do you have an idea for create logic inside e.g ESP32?
Thank you in advance.
Hello @misa15, apologies for the delay in response. Unfortunately, the Condens GC2300 iW 22/25 is not compatible with our Bosch Smart Home System. You may use the Bosch Smart Home Radiator Thermostat I in combination with Easy Control CT 200 to control your heating system.
Best regards, Philip
