Room thermostat and radiator regulator together working without network
misa15
Hello,
in room are installed room thermostat and radiator regulator (interconnected in application Smart Home App).
Will work, when
- Smart Home Controller will be disconnected?
- Smart Home Controller will be ON, but internet will be disconnected?
Thank you.
@misa15 The room and radiator thermostats only work together with the Controller. You can also combine RT I (867 MHz) and HT II (2,4 MHz, ZigBee 3.0) with the controller.
Internet is not mandatory, but without internet you will have no remote control and will not get updates.
