Smart home Controller - measure temperature and humidity + calculate dew point
misa15
Hello,
exist any possibility (with Smart home Controller) to
1. measure temperature + humidity?
2. Calculate from measured temperature and humidity a dew point?
3. Base on calculated dew point create the rule?
Thank you in advance.
4 ANTWORTEN 4
@misa15 please check if the Twinguard meets your requirements.
1. Yes, with a Raumthermostat or Twinguard.
2. No.
3. No, but you can trigger automations when the measured temperature and / or humidity is greater or less than a specified value. Something like "IF temperature < 22° AND humidity > 60% THEN ..."
Home Assistant User seit 2026
misa15
Thank you very much for precise answer.
It is possible to export data from Roomthermostat or Twinguard to csv?
Only by using the REST API. The Smart Home App doesn't have any data export features.
