am 13. September 2022 14:10
Hello,
exist any possibility (with Smart home Controller) to
1. measure temperature + humidity?
2. Calculate from measured temperature and humidity a dew point?
3. Base on calculated dew point create the rule?
Thank you in advance.
13. September 2022 14:27 - bearbeitet 13. September 2022 14:29
13. September 2022 17:39 - bearbeitet 14. September 2022 11:38
1. Yes, with a Raumthermostat or Twinguard.
2. No.
3. No, but you can trigger automations when the measured temperature and / or humidity is greater or less than a specified value. Something like "IF temperature < 22° AND humidity > 60% THEN ..."
am 14. September 2022 09:01
Thank you very much for precise answer.
It is possible to export data from Roomthermostat or Twinguard to csv?
am 14. September 2022 11:41
Only by using the REST API. The Smart Home App doesn't have any data export features.
